    The number dials but hangs up before the call is connected. I have done both soft and hard reset, checked all settings. Still won't call out. It receives calls and able to text out.
    06-16-2019 01:02 PM
  2. mustang7757's Avatar
    Which carrier you using ? Does it give a error code when trying call out?
    06-16-2019 01:39 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Have you already asked your carrier about this?
    06-18-2019 11:42 PM
  1. Why is my wifi say disabled
    Last Post: 06-18-2019, 11:07 PM
  2. "watermark" on top of my screen
    Last Post: 06-16-2019, 02:21 PM
  3. I saved a note to my folder... where is it
    Last Post: 06-16-2019, 01:59 PM
  4. Why cant I uninstall, useless built in apps on my Samsung Galaxy
    Last Post: 06-16-2019, 11:45 AM
