    How many times can a 3000mAj rated power bank charge a Samsung Galaxy Note edge?
    06-22-2019 04:48 AM
  2. Mooncatt's Avatar
    If you're talking about the original Note Edge, it has a 3000mAh battery as well. Due to inefficiencies inherent in charging batteries (especially from another battery), that doesn't mean the power bank will charge a full 3000mAh into the phone. You may be lucky to get about 75% charged once, if the phone is turned off during charging.
    06-22-2019 05:38 AM
  3. Mike Dee's Avatar
    If the phone is at zero they will only get about 50%
    06-22-2019 10:11 AM
  4. Mooncatt's Avatar
    I've never used a power bank, so I wasn't sure how much of a loss there was, only that there is some.
    06-22-2019 11:24 AM
  5. Mike Dee's Avatar
    It's not actually loss, it's just once the power equalizes between devices the current stops flowing. Both the juice pack and the device end up with 1500mAh
    06-22-2019 11:33 AM
  6. Mooncatt's Avatar
    "Semantics"
    06-22-2019 06:14 PM
  7. Mike Dee's Avatar
    "Semantics"
    Well I was speaking in technical terms because there will be some loss during the transfer which is a bit different. The loss is the heat you feel during transfer or charging.
    06-22-2019 06:49 PM
  8. mustang7757's Avatar
    Depends what brand your using and such but they usually tell you about 500 cycles
    06-22-2019 07:02 PM
  9. chanchan05's Avatar
    Actually you can't tell how many times a power bank can charge a phone from the rated mah capacity alone. You also have to consider the voltage the battery stores it in. The batteries in the powerbank stores 3000mah in 3.7-4.2 volts, depending on the battery type. Let's say it stores in 3.7 volts of 3000mah. The USB outputs at 5volts though.
    3.7 x 3000 /5 = 2220mah
    So the powerbank is only able to supply 2220mah out of the USB port, then you have to factor in heat loss. My guesstimate will be it will be able to give 2000mah.
    If you're talking about the old Note Edge, then it will give you around 60%. If you're talking the new Note 9, it won't even be 50% of the full charge.
    Of course this also depends on the brand. For example, Samsung mah statements on their powerbanks state the output mah, so for example their 5000mah powerbanks actually contain like 7000mah batteries or something like that. Another brand I know of that claims to advertise "actual" charging capacity of their power banks is Romoss. I have no idea of brands like Anker, Aukey, or Tronsmart advertise the battery capacity or charge capacity. I use a Bavin powerbank, been using it for 2 years and it serves me well. It has a 9000mah battery capacity, so it charges my S9 twice.
    06-22-2019 07:03 PM
  10. Mike Dee's Avatar
    You are correct but In the case of the charger the OP mentiond it can't even charge it once assuming the Note is at zero. If the Note is apx at 50% it may not get a 100% charge.
    06-22-2019 07:14 PM
  11. Mike Dee's Avatar
    The OP's question is unclear. I thought he was asking how many times can he charge his device without recharging the juice pack.
    06-22-2019 07:16 PM
  12. mustang7757's Avatar
    Yeah , I took it as how many times the power bank will charge their phone according to the title.
    06-22-2019 07:19 PM
  13. B. Diddy's Avatar
    Man, I sure hope the OP is enjoying these detailed replies.
    06-24-2019 01:58 AM
  1. CPU Overheating Problem on Galaxy Note 8
    By Key Lime 314 in forum Samsung Galaxy Note 8
    Last Post: 07-03-2019, 12:42 PM
  2. Galaxy S7 Signal / Reception Strength
    By ucpa111 in forum Samsung Galaxy S7
    Last Post: 06-24-2019, 01:23 PM
  3. How can I stop this google text to speech in tecno wx3
    Last Post: 06-23-2019, 10:20 PM
  4. How to stop full screen ads in Nokia 6.1 plus Android one phones
    Last Post: 06-22-2019, 02:52 AM
  5. How to fix my flashlight on lg stylo 4
    Last Post: 06-21-2019, 09:53 PM
