    I have tried power in my samsung galaxy S7 edge using other leads and multiple socket, unfortunately the same thing happened. Does the battery life span is due. This is also happened to my other set i.e Samsung Note 5. Do I have to change to a new battery? I am using the set for more than 3 years.
    06-24-2019 09:44 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Depending on what your battery usage habits are, 3 years can certainly be consistent with a failing battery. You probably would need to replace the batteries.
    06-25-2019 02:09 AM
  1. My battery drains way too fast
    Last Post: 06-27-2019, 12:21 AM
  2. Replies: 2
    Last Post: 06-25-2019, 12:48 PM
  3. Replies: 9
    Last Post: 06-25-2019, 12:24 PM
  4. "Samsung Galaxy apps is disabled. To enable it, tap settings"
    Last Post: 06-24-2019, 10:34 PM
  5. How to connect to public cloud printer from Android 5.0
    Last Post: 06-24-2019, 04:29 PM
