Basically it forces those apps you don't need running into sleep. If you have battery problems, it's probably a bad battery.
For longest life, keep the battery between 40% - 95%. If it gets down to 40% and you can't charge it, turn it off. (Lithium batteries are thin and light, they're not deep-discharge batteries.)
