    My Nexus 6P shuts down early, while still having 80% to 90% battery left and it doesn't start up unless I connect it to the charger.
    Ive tried several things, like clearing the cache, doing factory resets but nothing works. I contacted the manufacturer and they refused to fix or replace the phone because it's over one year warranty.
    Aubree
    07-08-2019 03:54 AM
  2. Android Central Question's Avatar
    I have a qlink phone. It's a hot chili Android with a SPRINT SIM card with QLINK SERVICE.
    I NEED TO UNLOCK THE SIM CARD, HOW DO I GET THE PUK CODE?
    FROM SPRINT OR QLINK?
    07-08-2019 03:57 AM
  3. hallux's Avatar
    The PUK code is for the SIM card - go to Sprint...
    07-08-2019 04:55 AM
  4. Rukbat's Avatar
    That's a bad battery (Lithium Battery Dendrite links). You'll have to get it replaced.
    07-08-2019 12:41 PM
  5. Rukbat's Avatar
    The PUK code unlocks the inability to put in the unlock code, but you still need the unlock code. Since you're a customer of QLink's (Sprint's customer of record is QLink, not you), and I'm pretty sure that QLink doesn't allow unlocking unless the phone is already unlocked when they get it, the PUK won't do you any good. The phone will still be locked to Sprint. (And unless it's a newer phone, the only other carrier it may work on is Verizon, and they don't accept Sprint phones, unlocking it serves no purpose.)
    07-08-2019 12:46 PM
  1. Always on display - Sometimes cut in half problem
    By felloffthetruck in forum Samsung Galaxy S10 & S10+
    Last Post: 07-08-2019, 09:45 AM
  2. Having some problems with Wi-Fi at this moment in time. Please help.
    Last Post: 07-08-2019, 01:06 AM
  3. Problem with factory reset and my SD card.
    Last Post: 07-06-2019, 04:36 PM
  4. Font color problems after system update
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 07-05-2019, 08:53 PM
  5. Font color problems after system update
    Last Post: 07-05-2019, 01:39 PM
