A
Android Central Question
I am using Android 8.1. All updates are installed.
When I hit a "key" on the keyboard, there is no sound.
When I go through all the settings, I check the settings for sound on the keyboard.
It is set to ON. Just to make sure, I turn it OFF and back ON again.
After that, when I use the keyboard, the sound is there.
But after a restart or turn OFF and ON my tablet, the sound is gone again.
Only when I go to the settings and turn it OFF and ON again, the sound is back again.
It is a bit annoying, to every time turn OFF and turn ON the settings, to have the sound again.
Hope anyone has a permanent solution for this.
Many thanks for the tips and trick.
great hope it stays that way
