    I have a LgL58Lv Version 6.0.1 And when I plugin my usb drive to my Otg it does not Recognize my usb. I waited till my phone turn on And plugged it in again But it still did not work. it Does not give me a notification on the top of my screen. Please help me. [Email removed - ask here, answered here.]
    07-31-2019 12:32 PM
  2. Rukbat's Avatar
    Are you using an OTG adapter? Or is the USB drive an OTG USB drive (most aren't, you need an OTG adapter or cable).
    If you're hooked up properly (OTG USB drive or normal USB drive with an OTG adapter or cable), does a PC recognize the drive? If not, the drive is shot.
    Then again, a phone that old probably doesn't support OTG.
    07-31-2019 03:57 PM
  1. Smart Lock - I don't want it...!
    Last Post: 08-01-2019, 03:11 PM
  2. Can I UNBLOCK my voice and data
    By Shea Arnold in forum LG Stylo 4
    Last Post: 07-31-2019, 11:39 PM
  3. How do I get signature on text message for my Samsung Galaxy on5
    Last Post: 07-31-2019, 11:32 PM
  4. Why can't I get games on my phone
    Last Post: 07-31-2019, 03:24 PM
  5. how do i install apps directly to my sd card
    Last Post: 07-31-2019, 02:29 PM
