Why does my LG V40 ThinQ have problems with Wi-Fi connection after the Android Pie update?
  • Start date Start date
A
Android Central Question
My LG V40 ThinQ (T-Mobile) has issues after the Android Pie update. When I switch on the WiFi, the network signal drops immediately and goes back on after several seconds, and then drops again and it happens over and over again. I have to put the phone in airplane mode so I can keep my Wi-Fi on. I really need some help.
Have you tried turning mobile data off first, then turning WiFi on? (You can't be on the internet through two separate paths on a phone, it's not a dual-homed server.)
sshkjgh7788
