    It’s like two circles with joined by a small bar
    08-15-2019 04:13 AM
  2. hallux's Avatar
    Swipe down on your notification bar and you should see the associated notification. You could then tap on that to open the app or long-press on it to get an option to show app info.
    If this is not on your device, I'll guide you to this sticky thread - https://forums.androidcentral.com/as...aped-icon.html
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    08-15-2019 04:28 AM
  3. methodman89's Avatar
    Join and post a screenshot of it.
    08-15-2019 06:41 AM
  4. B. Diddy's Avatar
    Two circles gettin' it on!
    08-15-2019 11:36 AM
  1. why my phone didn't have the notification files in internak storage?
    Last Post: 08-20-2019, 08:06 PM
  2. Update quesion.Help please.
    By Hodaka in forum Samsung Galaxy S9 & S9+
    Last Post: 08-15-2019, 07:33 AM
  3. Replies: 3
    Last Post: 08-15-2019, 12:39 AM
  4. Does the Samsung Gear S3 LTE (SM-R765) work in Canada?
    By Android Central Question in forum Samsung Gear S3
    Last Post: 08-15-2019, 12:37 AM
  5. How do i fix the touch feedback in certain area?
    Last Post: 08-15-2019, 12:34 AM
