    My camera mini5 ginoee is writing unable to connect with the camera pleasecheck wether the camera is inuse or restart the phone.
    09-01-2019 02:31 PM
  2. hallux's Avatar
    Your subject doesn't match your question, I'm confused. Not knowing what "it" is, we can't answer the subject question.
    As for the second - it sounds like either an app has taken over the camera module (HAVE you restarted?) or maybe the module has failed and is making the OS THINK an app has taken it over.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    09-01-2019 02:59 PM
  3. Rukbat's Avatar
    If restarting the phone doesn't fix it, restart in Safe mode:
    • Start by turning off the phone by holding the Power button for a while.
    • Then press and hold Volume Up + Power key for a couple of seconds.
    • You can release held keys when you see an Android Image on the screen.
    If that fixes it, one of the apps you installed is causing the problem. If it doesn't, the camera module is probably bad, and has to be replaced.
    09-01-2019 03:09 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Also see if it works in Safe Mode.
    09-01-2019 08:49 PM
  1. Replies: 2
    Last Post: 09-01-2019, 08:56 PM
  2. how can I remove flexkey from my phone without giving my google pswd?
    Last Post: 09-01-2019, 08:51 PM
  3. Facebook marketplace-listings are not visible to buyers
    Last Post: 09-01-2019, 03:10 PM
  4. Going from Tmo & N9 to Sprint &N10+
    By theshaz in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-01-2019, 03:05 PM
  5. how can hide the location in my samsung j7 ?
    Last Post: 09-01-2019, 02:40 PM
