    I have a prepaid ATT Samsung device, if model is relevant I can provide.
    So my phone is only a couple months old and the battery has been regularly lasting several days at a time, so no reason to suspect a battery issue.
    However, today it was sitting around 25% but the next time i checked it it had died. I powered it back on and it turned on but displayed a 0% battery and died immediately. I have been charging it for about an hour and it wont go beyond 0% and dies if i unplug from the charger.
    Again, the battery has shown no signs of dying and is pretty new so I suspect so kind of software or hardware issue.
    Any ideas of what caused this and how to fix it?
    Thank you.
    09-01-2019 05:41 PM
  2. belodion's Avatar
    Battery or related hardware failure, perhaps.
    09-01-2019 05:44 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Which Samsung phone? Did you get it brand new, or refurbished/used?
    Plug it into a wall outlet and let it charge for at least 6 hours undisturbed. Then press and hold Power for about 20 seconds to see if it turns on. If it doesn't, then the battery probably failed. If it's a refurb or used phone, then the battery may have been used heavily by the previous owner and was already on its way out when you got the phone (refurbishment doesn't mean they replace the battery). If it's a brand new phone, then the battery is probably defective -- you should be able to contact Samsung for warranty replacement in that case.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    09-01-2019 08:24 PM
  1. Got my battery case for my 10+
    By KoukiFC3S in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-14-2019, 09:26 PM
  2. Cause I use it to power my phone
    Last Post: 09-01-2019, 08:49 PM
  3. how to communiciting with a google service
    Last Post: 09-01-2019, 08:30 PM
  4. How I used my $200 and your thoughts..
    By photogwilly in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-01-2019, 05:39 PM
  5. start unlimited and hotspot
    By jgorda in forum General Carrier Discussion
    Last Post: 09-01-2019, 05:19 PM
