    I noticed that when I call someone, there is a blinking light on the right side of the front camera?
    Im just wondering what is it (or a sensor?) Can it be activated as notification light or whatever. Thanks
    09-07-2019 01:26 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's the proximity sensor: https://www.droid-life.com/2019/08/2...ot-dead-pixel/
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    09-07-2019 01:28 AM
  3. Rukbat's Avatar
    And no, you can't activate it as an indicator. (You could install Proximity Service, but then every time you put your hand near it, the screen will black out [which is the purpose of Proximity Service]).
    09-07-2019 03:45 PM
  4. B. Diddy's Avatar
    You could see if the camera LED flash can be used as a notification light: https://forums.androidcentral.com/e?...token=pWtZNImj. Not sure if it works on the Note10, though.
    09-07-2019 04:50 PM
  1. Is it possible to disable the HAXM feature required for an AVD based on Intel x86 CPU?
    By Thomas_George in forum Software Development and Hacking
    Last Post: 09-09-2019, 02:43 AM
  2. Samsung Wireless Charger 10,000 Battery pack gets mighty hot
    By felloffthetruck in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-07-2019, 08:07 PM
  3. Camera Burst Mode Not Working after 10
    By pjeverly in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 09-07-2019, 06:34 AM
  4. Replies: 1
    Last Post: 09-07-2019, 12:07 AM
  5. How can I get a photo back after I deleted the whole text
    Last Post: 09-07-2019, 12:01 AM
