1. bluenoser1's Avatar
    tried power saving mode...ultra
    next morning phone gives black screen
    09-08-2019 02:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you sure the phone is still even powered on?
    09-08-2019 02:28 PM
  3. bluenoser1's Avatar
    Tried just about everything regarding power options...like holding power button etc
    09-08-2019 03:10 PM
  4. Rukbat's Avatar
    Try the charger for about an hour. Then try the power button. Then finish charging the phone. (Next time don't let the battery drop below 40% - either charge it or turn it off.)
    09-08-2019 04:45 PM
  5. bluenoser1's Avatar
    ok already tried it .....will do it again
    09-08-2019 06:00 PM
  6. B. Diddy's Avatar
    If it still doesn't work after an hour, then let it continue charging for at least 6 hours undisturbed. Then press and hold Power and Vol Down for about 20 seconds to force a shutdown (in case the phone is actually frozen on a blank screen). Then press and hold Power for about 20 seconds to see if anything happens.
    You could also try using a different charging cable/plug. If that doesn't help either, then the battery may have failed.
    09-09-2019 10:57 PM
  7. mustang7757's Avatar
    Yeah definitely keep a charger on it for at least 30 minutes , should have a red notification light to let you know it's charging , after that 30 minutes try power button and volume up for around 10 seconds see if it can get you in recovery or feel I vibration.
    09-09-2019 11:08 PM
  1. Samsung Screen Protector
    By Joshua_Muldoon in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-18-2019, 06:56 PM
  2. Pairing SM V700 to SM-G970U
    By LadyDi in forum Samsung Galaxy S10e
    Last Post: 09-13-2019, 02:40 AM
  3. Replies: 3
    Last Post: 09-08-2019, 05:32 PM
  4. video/chat via phone-to-phone WiFi or BT?
    By Gary02468 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-08-2019, 12:09 PM
