    My android power x phone was updating firmware and I unplugged it
    09-10-2019 06:46 PM
  2. belodion's Avatar
    I don't know what happens, but try a Cache Partition wipe. https://forums.androidcentral.com/sh...d.php?t=409154
    09-10-2019 06:49 PM
  3. mustang7757's Avatar
    If power x is software tool , you bricked your phone, need to reflash
    09-10-2019 07:03 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! I assume "power x phone" means the LG X Power. Do you mean that it was downloading and installing a system update over-the air, and you unplugged the power in the middle of the process? If so, did the phone suddenly power off due to low battery? It's never a good thing to shut off a phone while a system update is in progress -- that often bricks a phone. But if the phone remained powered on after unplugging it from the power outlet, then it shouldn't be a problem.
    Another possibility is that you were updating via LG Bridge on your computer, with the phone connected via USB. Did you unplug that connection in the middle of the update?
    Rukbat likes this.
    09-10-2019 10:51 PM
  1. Verizon UDP on DPP
    By motomd in forum General Carrier Discussion
    Last Post: 09-15-2019, 05:40 AM
  2. No toggle for Fast Wireless Charge on N10+
    By cache11 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-12-2019, 12:57 PM
  3. My last cleabing app disappeared how do i get it backwant last cleaning aop
    Last Post: 09-11-2019, 03:18 PM
  4. Replies: 4
    Last Post: 09-11-2019, 09:55 AM
  5. apps are downloading but are not installing onto phone.
    Last Post: 09-10-2019, 10:55 PM
