    So I have this Galaxy S6 edge and I've been doing a bit of flashing for the past couple of days. But at this point the device is almost unusable. It only runs when the charger is connected, and shuts down when its removed. And when I try to power it up again, It shows the Samsung Galaxy S6 Edge logo and shuts down. But the wierd thing is, I know the battery is not dead. I've been in the Odin mode for hours and it doesn't power off, same goes for TWRP with maximum brightness. Can anyone please help me out I've tried everything(except battery callibration).
    So these are the outline :
    - The problem started from yesterday and it used to stay on for a few minutes at first. Now it doesn't even get past the first screen.
    - The phone reboots also when plugged in, but to a lesser extent.
    - Battery is probably good because it stays alive in recovery and Odin mode.
    - Everytime I charge it to 100%, I try to power it on with the charger unplugged, but it shuts down showing the Samsung screen. Then when I plug it in again, it shows 5%-15% charged and goes on to charge for 100% again.
    Please look on into it I'm having a very bad time.
    09-12-2019 01:56 PM
  2. Rukbat's Avatar
    Download the latest ROM for your variant, country and carrier. Flash it. If that fixes it (I suspect it will), whatever you flashed before has a problem.
    09-12-2019 03:14 PM
  3. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-12-2019 03:46 PM
  4. Sajid Zakaria's Avatar
    09-13-2019 08:15 AM
  5. Sajid Zakaria's Avatar
    I have tried everything Flashed the latest, second latest. It's just not working. Is there anything else you can think of?
    09-13-2019 08:18 AM
  6. Sajid Zakaria's Avatar
    One more thing, do I need to flash the firmware that has the 4 files(CM, CSC, AP...), or the one like rom.tar.md5 would work?
    09-13-2019 09:04 AM
  7. Sajid Zakaria's Avatar
    One more thing, do I need to flash the firmware that has 4 files(CM, CSC, AP...), or the one like rom.tar.md5 would work?
    09-13-2019 09:29 AM
  8. mustang7757's Avatar
    Yes put all files in corresponding slots
    Bl in Bl
    App in Ap
    CS in Cs
    CSC in CSC can use home CSC dont wipe data
    09-13-2019 09:31 AM
  9. Sajid Zakaria's Avatar
    Bl in Bl
    App in Ap
    CS in Cs
    Doesn't work
    09-14-2019 05:02 AM
  10. Galactic Zoo's Avatar
    In what way doesn't it work? This could mean anythong. eg you can't connect to the phone or the flash failed. Whay error message do you get. You haven't given us anything to go on.
    Please clarify what you mean.
    You could also try Emergency Firmware Recovery in Smart Switch
    09-14-2019 08:38 AM
  11. mustang7757's Avatar
    Doesn't work
    Which Odin you used?
    Galactic Zoo likes this.
    09-14-2019 09:05 AM
  1. Using the TAB 6 in a work enviornment
    By alodar101 in forum Samsung Galaxy Tab S6
    Last Post: 09-25-2019, 07:58 PM
  2. No mobile data connection on Samsung A50 following update
    Last Post: 09-14-2019, 06:02 AM
  3. Samsung S8 - Factory Reset and a MDM Pain!
    By Villordsutch in forum Samsung Galaxy S8 & S8+
    Last Post: 09-13-2019, 01:44 PM
  4. Found Official Samsung Galaxy Note 10+ Clear Case on Mobile Fun
    By YaniCruz in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-12-2019, 04:16 PM
