    if i charge it to 100 in like 5 minuts it will be on 89 percent its not suppose to drain so fast like that
    09-15-2019 12:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device? How old is it?
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html. Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    09-15-2019 12:46 PM
  1. Pixel 2 XL won't charge after Android 10 update
    By AKAndy in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-16-2019, 06:28 PM
  2. Y my flashlight is di
    Last Post: 09-15-2019, 12:54 PM
  3. Does my phone have a virus or something?
    Last Post: 09-15-2019, 12:48 PM
  4. Netflix autoplay not working on Note9
    By Notey9 in forum General Help and How To
    Last Post: 09-15-2019, 11:58 AM
