1. AmrdoidUser's Avatar
    So i've been having a problem where if i leave the phone untoched for too long, it will in a way lock but not really. What happens is a lock pops up on the screen and you have to swipe it to get it unlocked. I was wondering if there was a way to disable that happening in the first place. It only happenst to me, when a app/game is open.
    09-21-2019 12:38 PM
  2. mustang7757's Avatar
    It's a Android security feature
    09-21-2019 01:29 PM
  3. Rukbat's Avatar
    If you don't care about security too much, you can set up Smart Lock. (But it's a bad idea, unless you live alone and only set it to stay unlocked at home.) Or you could just set up fingerprint unlock. One touch and it's unlocked. (Write the password or PIN down and stick it in a sock drawer, just in case.)
    09-21-2019 01:50 PM
  4. AmrdoidUser's Avatar
    I have a PIN and everything, it's not like it completely locks, you just have to swipe without a finger print, PIN or anything.
    BTW i did try the Smart Lock thing it didn't work.
    09-22-2019 07:20 AM
  1. Why doesn't my Axia let me have a different home and lock screen
    Last Post: 09-23-2019, 11:29 AM
  2. Need Help - Root Samsung Galaxy Tab S2 SM-T817V
    Last Post: 09-21-2019, 02:10 PM
  3. Samsung Galaxy S8 Active restarts on incoming calls after Android Pie Update
    Last Post: 09-21-2019, 09:51 AM
  4. Little blue dot on screen
    By puchodog1977 in forum Samsung Galaxy Tab S6
    Last Post: 09-21-2019, 12:54 AM
  5. Galaxy j1 ace won't detect any sim
    By tracy barrie in forum Ask a Question
    Last Post: 09-20-2019, 01:52 PM
