A
Android Central Question
My new MiNote 7 with Android 9 has stopped 'ringing' when calls are received. I get vibration and light flashing but if I am not looking at the phone I do not know if someone is trying to call. Sound is on and turned up. I cannot find any obvious incorrect setting EXCEPT this may be part of a much wider problem. For many of my apps etc ACCESSIBILITY is not ACCESIBLE.
When I try to give access in the Accessibility Menu by clicking the on/off trigger I am taken to another 'service will be performed' window but on clicking OK a message flashes on (too) briefly about apps blocking a permission dialogue and to drag them away or close the app. I don't know what this means, it is incomprehensible to me as there is no blocking app present. Ironically, as well as this happening with numerous apps / settings etc it also happens when trying to access the Accessibility Menu itself! --- a sort of Catch 22 situation?
I expect I am failing to grasp something basic but need advice on how to escape from this before I go bananas.
