If the battery is normal (made 4 years ago), go through 3 cycles of charging it to 100%, letting it run until it's at 45%, then charging it again. That may bring a little life back.
And, as belodion asked, after letting it drop take a screenshot of the battery statistics. We may see something there that you can do to improve the battery life.
Also make sure your screen timeout is no longer than 30 seconds. (That's 30 seconds after you last did anything - you don't want the screen to stay on for 5 minutes after you put the phone away.) Lower the screen brightness unless you're outdoors during the day. (I get along on 15% [with 77 year old eyes] as set by Google Assistant.) Use the Back button when you finish using an app. (I know you see YouTube videos of people using the Home button, but that doesn't stop the app from running and using battery power, it just runs the home screen. It's the wrong way to use an Android phone.) These things may increase your time between charges.
And don't use any type of "cleaner" or "battery saver" app - they cost battery, they don't save it. (They kill running background code that Android needs, making Android load it again, costing battery. Google has gotten Android memory management pretty good by now, it doesn't need any help.)
