A
Android Central Question
This is a new problem following a forced upgrade to my Samsung Galazy S9 a week ago. When my phone is set to my wifi network, the connection to the Sprnt network stops. When I switch to mobile all works fine, but the connection to WiFi stops. Sprint insisted that was impossible. I finally changed to t-Mobile [after years of frustration on numerous issues and a better plan anyway]. During the in-store sign up I was told it didn't matter as my new plan had unlimited mobile data. As soon as I got home I turned my setting to my WiFi setting and immediately I lost connection to the T-Mobile connection. Turned WiFi off and the data connection came right back on. Called T-Mobile and they said "that's impossible". But it happens each time. So with WiFi on, no data; with WiFi off, data connection, but at some point this "unlimited data plan" will have limits of some kind. Is it me, my phone or what? PS-over 70 and low tech.
