    This is a new problem following a forced upgrade to my Samsung Galazy S9 a week ago. When my phone is set to my wifi network, the connection to the Sprnt network stops. When I switch to mobile all works fine, but the connection to WiFi stops. Sprint insisted that was impossible. I finally changed to t-Mobile [after years of frustration on numerous issues and a better plan anyway]. During the in-store sign up I was told it didn't matter as my new plan had unlimited mobile data. As soon as I got home I turned my setting to my WiFi setting and immediately I lost connection to the T-Mobile connection. Turned WiFi off and the data connection came right back on. Called T-Mobile and they said "that's impossible". But it happens each time. So with WiFi on, no data; with WiFi off, data connection, but at some point this "unlimited data plan" will have limits of some kind. Is it me, my phone or what? PS-over 70 and low tech.
    09-29-2019 12:32 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-29-2019 12:34 PM
  3. Mike Dee's Avatar
    How do you know you're only on one?
    Are you able to make calls when it's on WIFI?
    09-29-2019 12:44 PM
  4. Rukbat's Avatar
    Go to https://www.whatsmyip.org/ and see which one is connected to the internet under different conditions.
    09-29-2019 01:27 PM
  5. B. Diddy's Avatar
    Welcome to Android Central! I'm not quite clear on the problem -- are you saying that you want data to be coming over both wi-fi and mobile data at the same time? It's normal for the mobile data to pause while you're on wi-fi, since wi-fi is being used for data. Or are you saying that when you're on wi-fi, you can't even make a call?
    09-29-2019 02:12 PM
  6. ManiacJoe's Avatar
    It seems that the default setup of most phones is to turn off the cellular radio when the wifi is connected.
    If you want both wifi and cellular radios to be active, you can turn on the "developer" options, then turn on the "cellular data always active" setting. (Your option naming may be different.)
    09-29-2019 07:03 PM
  7. Mike Dee's Avatar
    As far as I know when you turn on WIFI it just sends data to WIFI. You are still connected to the LTE network for calls. Why does my data connection stop when I connect to wifi?-screenshot_20190929-220519_signalcheck-20pro.jpeg
    09-29-2019 10:07 PM
  8. ManiacJoe's Avatar
    Yes, the phone call system is always active. The cell data system by default gets turned off when the wifi data system is connected. When the cell data system remains on, there is no delay when swapping between the two systems nor any "temporarily not available" error when an app tries to directly connect to the cell data system like some voicemail apps like to do.
    09-30-2019 12:29 AM
  9. methodman89's Avatar
    Check the 2 settings I've circled
    09-30-2019 05:18 AM
  10. Mike Dee's Avatar
    Until the OP signs up we can't come up with a solid solution.
    09-30-2019 06:29 AM
  1. When will the LTE model of Active 2 be available? Only bluetooth model is available now.
    By Android Central Question in forum Samsung Galaxy Watch Active 2
    Last Post: 10-28-2019, 08:46 AM
  2. Dark mode - sunrise to sunset
    By DeepSeaGoddess in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-01-2019, 02:25 PM
  3. I had miravision on my phone and now it's gone
    Last Post: 09-29-2019, 03:49 PM
  4. Why are my renamed video files disappearing overnight?
    By ahmedy in forum Ask a Question
    Last Post: 09-29-2019, 02:17 PM
  5. Replies: 0
    Last Post: 09-29-2019, 11:26 AM
