A Android Central Question Oct 14, 2019 #1 A new icon has appeared in the status bar of my phone. It has the same outline as the battery icon, but has a rounded triangle shape inside, similar to the universal "recycle" symbol. Any guesses?
Javier P Ambassador Feb 21, 2014 19,480 3 0 Visit site Oct 14, 2019 #2 Welcome to the forums. What phone do you have? That icon probably means that Battery Saver is enabled. I would recommend you to create an account so you can reply on this thread. Upvote 0 Downvote
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Oct 14, 2019 #3 Either that or, if there's a tiny exclamation point in the triangle, a bad battery. Upvote 0 Downvote
