    A new icon has appeared in the status bar of my phone. It has the same outline as the battery icon, but has a rounded triangle shape inside, similar to the universal "recycle" symbol. Any guesses?
    10-14-2019 09:18 AM
  2. Javier P's Avatar
    Welcome to the forums. What phone do you have? That icon probably means that Battery Saver is enabled.
    I would recommend you to create an account so you can reply on this thread.
    10-14-2019 09:20 AM
  3. Rukbat's Avatar
    Either that or, if there's a tiny exclamation point in the triangle, a bad battery.
    10-14-2019 01:24 PM
  1. One ui 2.0/android 10 beta is now live!
    By Jesus Delgadillo in forum Samsung Galaxy S10 & S10+
    Last Post: 12-23-2019, 02:35 PM
  2. Has anyone else seen or read this? Could this affect the Note 10 & 10+ series?
    By Samsmome in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 10-25-2019, 09:40 PM
  3. Replies: 3
    Last Post: 10-14-2019, 06:59 PM
  4. Replies: 7
    Last Post: 10-14-2019, 01:15 PM
  5. Replies: 2
    Last Post: 10-14-2019, 12:58 PM
