How can I disable Safe Mode on Huawei when my power button does not work?
helpmeandroidpeople
For some reason my Huawei Switched into Safe Mode and at the same time my power button broke. Now I can't switch it off anymore, thus, get out of Safe Mode. I also can't go the Play Store, to download an App that could turn off my phone, because all the third-party apps have been disabled in this mode. Is there another way on how to force stop the phone?
Resetting also isn't an option because I'd have to enter my pin code and the keyboard isn't working either, so... I'm pretty much helpless :/
The button just presses a switch inside. If the button broke, you should be able to reach inside the hole it left, with a wooden (or plastic) toothpick and press the switch. If it's the switch that broke, you just have to get it repaired. (And, if it's an older phone, it may cost more to repair than replacing it with a newer phone.)
HisQueen3232
