    Hey my Samsung galaxy s7 edge back rear glass broke because the battery got swollen. A new battery is inserted but the back bottom half of glass not there so the battery is partly exposed. Will this effect the usage of my phone, and will my battery be affected by this and the camera?
    11-10-2019 02:55 PM
  2. belodion's Avatar
    So the innards of the phone are open to atmosphere?
    11-10-2019 03:21 PM
  3. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    11-10-2019 04:01 PM
  4. mustang7757's Avatar
    Having a back exposed like that means any dust or water can get into the phone , my suggestion replace the back ASAP
    11-10-2019 04:03 PM
  5. me just saying's Avatar
    it is near impossible for us to know if there will be a problem. just use the phone as normal and see if there are issues. one thing, if the opening is wide enough, then dust and other foreign can enter and cause problems. make sure you use a good case. IMO, when the battery was replaced, the frame should have be bent back into shape.
    11-10-2019 04:07 PM
  6. Rukbat's Avatar
    Unless you have the back replaced (by a Samsung-qualified shop), the phone is no longer dust or water resistant. And that could cause a problem. (If it's raining, or even foggy, and you have the phone exposed, it will be water-damaged.)
    11-10-2019 05:35 PM
  1. Erratic battery life
    By MarkA67 in forum Google Pixel & Pixel XL
    Last Post: 11-16-2019, 06:18 AM
  2. Faild to play video Unkown error has occurred
    Last Post: 11-10-2019, 12:20 PM
  3. Replies: 4
    Last Post: 11-10-2019, 12:19 PM
  4. Replies: 3
    Last Post: 11-10-2019, 12:17 PM
  5. Replies: 0
    Last Post: 11-10-2019, 06:10 AM
