A
That badI'm sorry to say this, but EMUI is a weak android skin. You can't even multiple select missed calls etc from calls list to delete. You have select them one by one for deletion or all.
In the emui file manager , you cannot multiple select files to check size either. Just a few examples.
Yep. Following comment is a joke be forewarned . They should have just been banned globally for their EMUIThat bad![]()
