1. James Anderson23's Avatar
    I downloaded the Zedge ringtone app and it's asking permission to write system settings, is it safe to do it or is something dodgy going on?
    11-29-2019 08:00 AM
  2. mustang7757's Avatar
    You can change that permission anytime you want if you don't feel comfortable. If you have further questions can register here as a guest can't communicate.https://forums.androidcentral.com/sh...d.php?t=409154
    11-29-2019 08:05 AM
  3. James Anderson23's Avatar
    Hey, just registered, cheers for the quick reply. What would an app use that permission for exactly? Is it so it can change my ringtone to the one I download or would it be something more complicated?
    11-29-2019 08:24 AM
  4. mustang7757's Avatar
    Hi , welcome!
    If you long press Zedge then tap info and scroll to permission it only ask for location, storage, contact , on mine I only grant storage so it can't download wallpaper or ringtones.
    11-29-2019 08:28 AM
  5. Javier P's Avatar
    Welcome to the forums. I think that permission is needed it to change the ringtone from Zedge. I guess you can deny that permission, download the ringtone, move it to the right folder and then pick it from the general settings or from a different app.
    Rukbat likes this.
    11-29-2019 08:28 AM
  6. B. Diddy's Avatar
    Welcome to Android Central! If it makes you uncomfortable, you can always just download the ringtone directly from the zedge.net website on your browser, and then use a file manager app to move that ringtone file to the /Ringtones, /Notifications, or /Alarms directory.
    Rukbat likes this.
    11-29-2019 12:09 PM
  7. Rukbat's Avatar
    Or "folder" as everyone calls it these days. B. Diddy and I come from the days when people spoke proper Computerese.
    B. Diddy and ManiacJoe like this.
    11-29-2019 04:32 PM
  8. B. Diddy's Avatar
    LOL, the reason I distinguish "folder" from "directory" is that there can be folder icons on the homescreen or in a gallery app that doesn't correspond to an actual directory pathname on Internal Storage or the SD card.
    11-29-2019 04:36 PM
  1. Full Backup twrp to pc direct
    Last Post: 11-30-2019, 12:35 PM
  2. How to open apk file on PC?
    By Buchheitpaul in forum General Help and How To
    Last Post: 11-30-2019, 12:15 PM
  3. Notification sounds from S8+ to S10+ change
    By omawb in forum Samsung Galaxy S10 & S10+
    Last Post: 11-29-2019, 09:41 AM
  4. Using only a usb cable to watch movies from your phone on my tv
    Last Post: 11-29-2019, 01:59 AM
  5. Full backup adb twrp to pc
    Last Post: 11-28-2019, 07:40 PM
