A
Android Central Question
Everytime my phone is somehow turned off or restarted, my phone data turns off for a bit. After 10-15 minutes, edge turns on. Then, after a few hours, my 4g finally turns on. Sometimes it takes around 12-20 hours for 4g to function. I only have this issue when the phone is turned off and I am looking for some sort of fix. I have a Galaxy J3 prime. The model number is SM-J327T1
