    I answered no to all access on contacts, now unable to call out
    12-06-2019 10:15 PM
  2. Javier P's Avatar
    Welcome to the forums. Which app is that? What phone do you have? Try this, go to settings - apps - select that app - permissions and enable that permission back.
    I would recommend you to create an account so you can reply on this thread.
    12-06-2019 10:19 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Just curious, how did you expect the app to behave when you turned off one of the permissions required for it to work correctly?
    12-06-2019 11:04 PM
  4. me just saying's Avatar
    unfortunately most permissions are required if you want apps and features to work properly.
    12-06-2019 11:12 PM
  5. belodion's Avatar
    I suspect that some people fear app permissions as being somehow invasive and malevolent.
    12-07-2019 07:06 AM
  1. What has happened to my battery
    By Stealthieone in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-12-2019, 02:42 PM
  2. Whats the pros and cons of the Samsung phones
    Last Post: 12-06-2019, 11:42 PM
  3. My favorite tray of apps have dropped down on my screen how do i pull it back up
    Last Post: 12-06-2019, 11:05 PM
  4. How to fix phone data stuck on edge when it is restarted
    Last Post: 12-06-2019, 04:34 PM
  5. Can you send and receive texts from specific phone numbers w/o it on you bill
    Last Post: 12-06-2019, 03:05 PM
