    I'm trying to figure out if I can get my phone to come on without a battery I charge in straight to the charging box and straight to the prongs where the battery is inserted it will come on and get all the way to the screen word it says AT&T after the LG screen and then it cuts off every time will this be possible to happen what should I do
    12-21-2019 11:36 AM
  2. mustang7757's Avatar
    It probably will come on directly to the prongs but after you disconnect it will turn off that's why it needs a battery , plus if you send voltage to wrong prongs you might end up with broken phone .'ll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.https://forums.androidcentral.com/sh...d.php?t=409154
    12-21-2019 11:39 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! It looks like replacement batteries are fairly cheap, so if it's important, just buy one: https://www.amazon.com/Best4Buy-Phoe...cUvbUpU6710096
    12-21-2019 11:48 AM
  4. Rukbat's Avatar
    The "charger" doesn't supply enough current to run the phone, just to charge the battery. (Which tends to indicate that there's something wrong with the phone.)
    12-21-2019 04:06 PM
  1. note9 Exynos Crap battery Eynos Note 9 Crap Battery
    By KingCustard in forum Samsung Galaxy Note 9
    Last Post: 12-24-2019, 04:11 PM
  2. Flash light is stuck in my phone. How to remove it and on flash light?
    Last Post: 12-22-2019, 06:37 PM
  3. whatsapp voice to text only works on wifi and not on my data
    By Android Central Question in forum Android Apps
    Last Post: 12-21-2019, 11:48 AM
  4. Heroes and Merchants - new ingame Dungeon Crawler (V1.7.0)
    By Andrea3980 in forum Android Games
    Last Post: 12-21-2019, 10:51 AM
  5. Replies: 2
    Last Post: 12-21-2019, 10:07 AM
