1. xMarc's Avatar
    I received a Netgear Wifi Extender EX3110 and everything works great. Signal is enhanced and there's no problem connecting.
    However, whenever my phone connects, my battery will drain very fast. Overnight, on standby, it will go from 50% to 6% in 7 hours. My phone is only 50' away from the extender and the signal is very high.
    What could be the issue with the battery drain when connected to the extender?
    01-09-2020 09:33 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is there anything unusual in the battery stats in terms of apps or services? Is Cell Standby really high?
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    01-09-2020 09:43 AM
  3. mustang7757's Avatar
    This started happening when you installed the wifi extender?
    01-09-2020 09:50 AM
  4. xMarc's Avatar
    Thanks, B. Diddy. I registered.
    I'll take a look at the battery stats later but now know that this is an issue only when connected through 5ghz. I lost about 5%/hour on standby where's only 1% on the 2.4ghz.
    Yes, Mustang. Today, I removed the 5Ghz wifi connection from my phone and have been fine. Not sure why that would be drawing so much more battery life since the extender is only 30-50' away and almost full bars.
    mustang7757 likes this.
    01-09-2020 03:11 PM
  5. mustang7757's Avatar
    Hi welcome ,
    My guess is the 2.4ghz has better penetration through rooms and stuff
    01-09-2020 03:19 PM
  6. Rukbat's Avatar
    If there's anything, not only 'rooms and stuff', blocking the 5GHz signal, that would do it. (Anything conductive that's an odd multiple of 6cm [2.3622"] on one side could do it.)
    01-09-2020 04:37 PM
  1. Samsung Replaceable Battery Phone
    By mrdave570 in forum LG V20
    Last Post: 01-28-2020, 02:40 PM
  2. Android Central App popup adverts esy way to get rid of them.
    By TheWounded in forum General News & Discussion
    Last Post: 01-12-2020, 06:45 AM
  3. 3.5 hours screen on time s10
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 01-11-2020, 10:52 PM
  4. How can I screen cast Moto G6 to Samsung SmartTV?
    By Aphelion Swarm in forum Moto G
    Last Post: 01-09-2020, 09:35 AM
  5. 3.5 hours screen on time s10
    Last Post: 01-09-2020, 08:14 AM
