    I have a case on my Galaxy S9+. When I had a ring holder on it, the standup charger wouldn't work. I think because it was too thick. When I removed the ringholder, it charges fine thru the case. I need something to help me hold the phone, and because the camera goes so far down on the back, I can't put a ring up high enough to clear the charger.
    01-10-2020 04:23 AM
  2. L0n3N1nja's Avatar
    If it doesn't work with a regular wireless charger it won't work with one that stands up. Nothing changes except how the device sits on it, all the charging coils in the phone are still going to be blocked by the ring.
    01-10-2020 04:30 AM
  3. mustang7757's Avatar
    I'll leave a link to register so you can communicate here , as a guest account you can't.
    https://forums.androidcentral.com/sh...d.php?t=409154
    01-10-2020 08:56 AM
  4. Rukbat's Avatar
    Wireless charging and thickness don't go together. If the total distance between the back of the phone and the charger is more than 5mm (about 0.2") it just won't work. If the case plus ring thickness is still under 5mm, it will - as long as the ring isn't metallic. (A metal loop in the charging field will just short-circuit the field, just like a metal loop in a microwave oven will get unbelievably hot [if it doesn't melt first, or burn the magnetron out first - but wireless chargers are protected against burnout, and can't put out enough power to melt a tinfoil loop].)
    01-10-2020 04:40 PM
  1. Can i take 3 photos with timer?
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 01-11-2020, 10:45 PM
  2. Bang & Olufsen E8 2.0 True Wireless Earphones
    By Hermes Hidayat in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-11-2020, 07:35 PM
  3. Can i take 3 photos with timer?
    Last Post: 01-10-2020, 01:58 AM
  4. androidcentral reset password not working
    By Android Central Question in forum Site Feedback & Help
    Last Post: 01-09-2020, 06:37 PM
  5. androidcentral reset password not working
    Last Post: 01-09-2020, 06:32 PM
