1. SneedBreedley's Avatar
    I have a Galaxy Avant. Every time I get in my car and my phone connects to the car's bluetooth, the phone makes the notification sound. I searched the internet high and low and every thread came up without a solution. HOW DO I TURN OFF THIS BLUETOOTH CONNECTION NOTIFICATION SOUND?
    01-16-2020 06:32 PM
  2. VidJunky's Avatar
    Found this old thread, the last post said there's an app called Bluetooth Notifier…?
    https://forums.androidcentral.com/as...ion-sound.html
    This thread from the Samsung site offers a solution...
    https://us.community.samsung.com/t5/...th/td-p/671974
    This one may be it though. About halfway down there's a solution that the commenter got several big thank yous for...
    https://forums.androidcentral.com/sa...i-disable.html
    01-16-2020 07:45 PM
  3. SneedBreedley's Avatar
    I found all those posts but not one applies to my phone.
    01-16-2020 08:44 PM
  4. mustang7757's Avatar
    You can try settings>apps>tap 3 dots upper right corner >system apps > scroll to Bluetooth and tap > tap notification and try playing with those settings
    01-16-2020 10:25 PM
  5. SneedBreedley's Avatar
    OK, here's how the Avant's settings go: Settings - Applications - Application Manager. If you select the 3 dots under "Application Manager", your only choices are "Sort by size" and "Reset App preferences".
    01-16-2020 10:50 PM
  6. mustang7757's Avatar
    There no Apps once you go into settings?
    01-16-2020 10:56 PM
  7. SneedBreedley's Avatar
    01-16-2020 11:08 PM
  8. mustang7757's Avatar
    What's under system or application ?
    Do any of those show list of apps ?
    01-16-2020 11:23 PM
  9. SneedBreedley's Avatar
    All the apps are listed under Application Manager. There is one app called Bluetooth share and one app called Bluetooth test. The only options are to Force stop, Turn off, Clear cache or Clear defaults.
    01-17-2020 06:58 AM
  10. mustang7757's Avatar
    What Android version you on ? It must be old one and might not work what I'm thinking.
    Here's my screenshotNow to Turn Off Bluetooth Connection Notification Sound?-screenshot_20200117-090731.jpeg
    01-17-2020 08:09 AM
  11. SneedBreedley's Avatar
    Android Version 4.4.2.
    01-17-2020 08:46 AM
  12. mustang7757's Avatar
    Yikes, I dont have a phone with that older OS
    01-17-2020 09:08 AM
  13. SneedBreedley's Avatar
    So is there a way to turn off the bluetooth notification sound in an Avant phone with Android Version 4.4.2?
    01-17-2020 03:59 PM
  14. mustang7757's Avatar
    It's been awhile since I played with older Android version like that , maybe some other members can chime in
    01-17-2020 04:16 PM
  1. Can I turn data on only when calling
    By Pbookuser2 in forum Ask a Question
    Last Post: 01-22-2020, 12:30 AM
  2. Can you help me connect to my google accounts?
    Last Post: 01-21-2020, 10:31 PM
  3. after upgrade to android 10 call quality is poor
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 01-21-2020, 12:28 PM
  4. Which App's notification symbol is this?
    Last Post: 01-16-2020, 05:24 PM
  5. after upgrade to android 10 call quality is poor
    Last Post: 01-16-2020, 04:44 PM
