    I've been trying to use a sports app called Ski Tracks while medium power saving is on.
    The problem is that once the screen turns off the app looses the GPS signal.
    It works fine if switch to optimised mode but I would like to use it with medium power saving enabled.
    My phone is Samsung s10e with android 10, oneUI 2.0.
    I've been trying various settings to make it work, my last configuration is :
    Disabled optimised battery for:
    Slocation
    Samsung location sdk
    Samsung positioning
    Ski tracks
    Alow location access all the time for:
    Ski tracks
    Adaptive power saving - off
    Adaptive battery - on
    Put unused apps to sleep - on
    Sleeping apps - Ski Tracks not in list
    Apps that won't be put to sleep: Ski Tracks can not be selected, since optimised battery is disabled for it.
    01-19-2020 05:56 AM
  2. anon(10614692)'s Avatar
    You are trying to get the phone to work in a way that it wasn't designed. Power saving always turns off gps
    01-19-2020 07:33 AM
  3. alex625's Avatar
    Hello, I am the author of the question.
    I want to add that I could do this with my previous phone with android 7 and it's a pitty that it's not working anymore.
    It was very useful in my opinion to have the benefits of power saving and in the same time to be able to use apps that track the position.
    01-19-2020 08:52 AM
  1. How to remove the little man inthe lower right corner android.?
    By Farfrompuking1 in forum General Help and How To
    Last Post: 01-21-2020, 03:23 PM
  2. How do I identify a phone case?
    By Red 3 in forum General Help and How To
    Last Post: 01-21-2020, 03:22 PM
  3. why won't my NEW s-10+ power on out of the box to start setup...
    Last Post: 01-21-2020, 01:49 PM
  4. Why am I unable to access properties from the apk base?
    Last Post: 01-20-2020, 01:58 PM
  5. Jbl charge 4 only can connect for audio and not calls?
    Last Post: 01-19-2020, 09:21 AM
