    Hi all,
    I have noted that my phone (Samsung A7 - 2018) is disconnecting every few seconds from my car (Volkswagen Polo 2019 model). The car shows that 'import failed' and retries within few seconds, but it fails again. During a call when the connection is established the call is transferred to the hand free system but after few seconds it disconnects again. The connection was working fine until my last software update on my phone in December 2019.
    Any idea how this issue could be solved?
    Thanks
    Clifton
    01-19-2020 02:32 PM
  2. mustang7757's Avatar
    Have you tested your car system with another phone to rule out that?
    I'll leave a link to register so you can communicate here, as a guest account u cant .
    https://forums.androidcentral.com/sh...d.php?t=409154
    01-19-2020 04:26 PM
  3. Rukbat's Avatar
    Either the phone is failing (as mustang said) or the car system is. Check with another phone, check with another car (at the VW dealer - same model).
    mustang7757 likes this.
    01-19-2020 04:30 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Does this also happen in Safe Mode? https://www.hardreset.info/devices/s...018/safe-mode/. Or after a cache partition wipe? https://www.hardreset.info/devices/s...recovery-mode/
    01-21-2020 02:52 PM
  5. dvandenhoek's Avatar
    This is an issue with the latest firmware for the Galaxy A7 2018, see https://eu.community.samsung.com/t5/...n/td-p/1498239
    B. Diddy likes this.
    02-02-2020 07:52 AM
  6. Viktor Varga's Avatar
    You have now 3 choices.
    1 wait for update by VW (but the problem is at Samsung side, J6,A5...other types are working)
    2 wait for update by Samsung for A7 (latest update 01.01.2020 is also not working)
    3 restore your A7 to 01.11.2019 Firmware (it's easy and working perfectly)
    Galactic Zoo likes this.
    02-10-2020 02:29 PM
  1. Incoming calls don't give sounds through Bluetooth device
    By BigDannyPt in forum General Help and How To
    Last Post: 01-25-2020, 12:18 PM
  2. I cant change my ringtone on my new Samsung a10
    Last Post: 01-21-2020, 01:45 PM
  3. my phone keeps reastarting and it wont charge properly
  4. My infinfix hot 5 is not vibrating? And all setting are on apps indicated
    Last Post: 01-20-2020, 02:03 PM
  5. Samsung Galaxy Tab A 10.1 doesn't charge, grey battery displayed
    Last Post: 01-19-2020, 02:44 PM
