    I don't understand directions given
    01-23-2020 07:03 AM
  2. Galactic Zoo's Avatar
    What directions?
    01-23-2020 07:25 AM
  3. Javier P's Avatar
    Welcome to the forums. Are you referring to a different thread on this forum? What steps have you tried so far? Have you already tried restarting the phone?
    I would recommend you to create an account so you can reply on this thread.
    01-23-2020 08:18 AM
  4. mustang7757's Avatar
    I'll leave a link to register so you can communicate here , as a guest account you can't.
    https://forums.androidcentral.com/sh...d.php?t=409154
    01-23-2020 09:50 AM
  5. belodion's Avatar
    Threads merged.
    mustang7757 likes this.
    01-23-2020 09:53 AM
  6. B. Diddy's Avatar
    Welcome to Android Central! The standard clipboard function is very transient -- it's only a part of RAM, not anything saved to internal storage. So the next time you copy something to the clipboard, what was previously saved to the clipboard is wiped out. I believe that it also clears when you reboot or power the phone off.
    Does your keyboard have an enhanced clipboard that allows you to save multiple items? Older Samsung phones had this, but not newer ones, I think. Gboard does have this feature, but you have to activate it, so if you don't recall doing that, it's still just the standard clipboard.
    01-23-2020 11:42 AM
  1. My S Finder keeps popping up
    Last Post: 01-23-2020, 03:25 PM
  2. Replies: 2
    Last Post: 01-23-2020, 12:01 PM
  3. how to see samsung calendar events on the google calendar on my PC
    Last Post: 01-23-2020, 11:55 AM
  4. My phone keeps restarting
    By PhoenixPixie33 in forum General Help and How To
    Last Post: 01-23-2020, 09:12 AM
  5. How do I clear clipboard on my Samsung J7 Sky Pro
    Last Post: 01-23-2020, 08:18 AM
