1. ZeroRin's Avatar
    i'm trying to record a music game. i want to record the screen as well as internal audio.
    however, all the tools i found have limitations:
    some apps record internal audio with microphone sound, involving the sound of tapping the screen, etc.
    some apps disables the audio output while recording. they can make perfect recordings but i cannot hear anything while playing.
    i want to record the game with internal audio only, and i want to hear the audio while recording. are there any tools to help?
    my device is samsung s9+, already rooted
    01-29-2020 02:20 AM
  2. VidJunky's Avatar
    My best advice would be to find a similar recording on YouTube and ask the channel how they accomplished it. I mean what you're looking for is rather specific and you're asking this in the general Ask a Question forum where you're not likely to find many users doing this specific thing. Since you have registered and can open search the forums, you might also consider asking this in the Game forums, where game devs. probably post videos of their games regularly in a way that is what you're looking for.
    01-30-2020 12:22 AM
  3. mustang7757's Avatar
    Since your rooted, probably have to find a screen record app , do you want me move this thread to s9 forums for see if you get better help there ?
    01-30-2020 09:46 AM
  4. ManiacJoe's Avatar
    If you are running android 9 or earlier, you might be out of luck. However, this app claims to have internal audio working again in android 10
    https://play.google.com/store/apps/d...nrecorder.free
    01-30-2020 06:33 PM
  5. belodion's Avatar
    22h later. I don't like to see a question unanswered, so would you like me to offer an answer?
    mustang7757 likes this.
    01-31-2020 04:35 PM
  6. mustang7757's Avatar
    Sure definitely
    01-31-2020 04:39 PM
  7. belodion's Avatar
    Sure definitely
    No thank you, I think it will be okay right here.
    01-31-2020 04:42 PM
  8. mustang7757's Avatar
    I agree
    belodion likes this.
    01-31-2020 04:45 PM
  1. Why can't I use the mic on my Galaxy Buds?
    Last Post: 01-29-2020, 01:11 PM
  2. Gboard not always working when trying to text
    By joe1blue in forum Samsung Galaxy S10 & S10+
    Last Post: 01-29-2020, 09:11 AM
  3. How to integrate a digitalfile into Skyfile in Android app?
    Last Post: 01-29-2020, 01:48 AM
  4. I have a lg k40 and while its on charge it goes down what can i do about that
    Last Post: 01-29-2020, 01:47 AM
  5. possible to unlock with either face rec or swipe?
    By lorraineg57 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-29-2020, 12:22 AM
