    I often turn my phone off to try to charge faster, but then need to use it before it's fully charged. Have often pressed the power button and let it boot while still connected to the charger. But I have no idea if the phone keeps charging at this point. Can anyone answer this? Thanks in advance.
    02-05-2020 04:20 PM
  2. anon(10614692)'s Avatar
    I have no idea but any change in status would be miniscule.
    Laura Knotek likes this.
    02-05-2020 04:38 PM
  3. mustang7757's Avatar
    'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    02-05-2020 07:36 PM
  4. Mike Dee's Avatar
    Are you referring to just while its booting up or using it while charging?
    While booting up it probably is still charging but even if it wasn't I'm not clear what the concern is.
    If you are using it while charging it depends on what your doing while using it. If your device has the capability to rapid charge it usually drops down to slow charge. If you use more power than the charger is putting out then it wont charge. I used the gps and Spotify at the same time in my car and it still charges with the screen on.
    02-05-2020 10:09 PM
  1. Replies: 28
    Last Post: 02-10-2020, 05:37 PM
  2. Why is my phone beeping weird?
    Last Post: 02-07-2020, 02:19 PM
  3. "Cut Copy Paste Share" pop up options seem to take forever...
    By Hanko in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 02-07-2020, 12:25 PM
  4. Virus on phone
    By GodlessCombo in forum General Help and How To
    Last Post: 02-07-2020, 12:02 PM
  5. My talk to text was working but it suddenly stoped
    Last Post: 02-06-2020, 07:50 PM
