    Please advise which media cord to get. I do not know the difference.
    02-09-2020 03:29 AM
  2. VidJunky's Avatar
    What phone do you have?
    I have to be honest with you if you have anything even 4 or 5 years old that is from a mainstream manufacturer the cables are one in the same. Micro USB and USB-C only come one way and they will handle data and charging.
    Now back in the day when everyone had their own plugs there was a difference because a cable could be made cheaply with only two or three leads for charging and 5, 6 or 7 if they had to do both.
    If you would like to reply to this thread please create an account. This link will help you do that... https://forums.androidcentral.com/as...-new-post.html
    02-09-2020 07:14 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! The only thing I'd add is that it's a good idea to stick with well-known manufacturers, and avoid no-name brands. There can be low quality cables that might cause some problems, especially with USB-C. Names like Belkin, Anker, and AmazonBasics are generally trustworthy.
    02-09-2020 12:51 PM
  4. Rukbat's Avatar
    I bought these a while ago, and have never had a problem (and they're considerably cheaper than most others). My phone is charging on one right now.
    02-09-2020 05:08 PM
  1. Why does Shop Samsung need access to my Contacts?
    By Trees in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 02-09-2020, 10:37 AM
  2. Why wont google respond.to.ANY QUESTION,AND WHY NO ONE.HAS A ANSWER FOR THAT?
    Last Post: 02-09-2020, 07:49 AM
  3. Replies: 1
    Last Post: 02-08-2020, 11:35 PM
  4. How do i know what type of otterbox i have and how do i get into it it
    Last Post: 02-08-2020, 03:38 PM
  5. Why does my Bluetooth keep turning on in my Xiaomi Redmi 6 and how do I stop it?
    Last Post: 02-08-2020, 02:08 AM
