1. Kawar's Avatar
    I need to know how with smart switch or some way to get everything from the old phone to mirror the new phone so everything is the same and i do not lose my contacts or my whatsapp messages both are very important I have everything backed up in like 5 places but i want a copy for copy and not sure how to do it the right way with smartswitch or what ever like i said.
    Can someone please give me detailed step by step please
    NOTE FOR THE MODS AND ADMIN IF YOU KNOW A BETTER HOME FOR THIS FEEL FREE TO MOVE IT Thank YOU
    03-09-2020 05:00 PM
  2. mustang7757's Avatar
    You can transfer contacts ,pictures, but dont do settings , it's too old to transfer your sertings, home screen stuff like that .
    If you made back up in smart switch just check the boxes for what I mentioned above same with if you had backed up to Samsung cloud in accounts>settings restore just check the ones I mentioned
    03-09-2020 05:24 PM
  3. Kawar's Avatar
    i just did a full restore the only thing that did not move over i think that i super need is whatsapp and i am useing google drive now no matter even if i really did not want 2.
    but please explain why its really 2 old?
    03-09-2020 05:36 PM
  4. mustang7757's Avatar
    Google drive is fine
    It's a older Android system compared to s20
    03-09-2020 05:42 PM
  5. mustang7757's Avatar
    From a s9 or s10 family ok but not s7
    03-09-2020 05:43 PM
  6. Kawar's Avatar
    really you would think if i was using smart switch it would not matter did i miss something with that thought?
    03-09-2020 06:13 PM
  7. mustang7757's Avatar
    Use it for only those things I mentioned , otherwise your going be doing Factory reset from a old back up like that , Trust Me I've been down this path and helped other members that have
    03-09-2020 06:25 PM
  8. Kawar's Avatar
    i think i did it the right way. i did not put my sd card in till after and i got all but maybe a few files and i can leave with that but i used smart switch for a full backup with out sd
    03-09-2020 07:28 PM
  9. mustang7757's Avatar
    Ok good , but did you transfer only what I said to s20?
    03-09-2020 07:50 PM
  10. Kawar's Avatar
    no I transfered everything from the backup I made 10mins before and everything works. Few apps needed updating but about it
    03-10-2020 06:35 AM
  11. Kizzy Catwoman's Avatar
    You are lucky. I restored from a backup between a Pixel 2xp and a 4XL and I had issues with my new hardware. I had to factory reset and set up as a new phone to get it to work.
    mustang7757 likes this.
    03-10-2020 06:45 AM
  12. mustang7757's Avatar
    If you have any issues with greyed out menus or not available, you'll have to factory reset .
    03-10-2020 09:03 AM
  13. mustang7757's Avatar
    I agree
    03-10-2020 09:03 AM
  14. Kawar's Avatar
    What do you mean like in the network settings one of the other posters told me to check lot of that is grayed but the name is that a big deal?
    03-10-2020 09:59 AM
  15. mustang7757's Avatar
    Yeah if setting are greyed out , things won't work as should
    03-10-2020 10:38 AM
  16. Kawar's Avatar
    What do you think is everything working from the sounds of it
    03-10-2020 11:18 AM
  17. mustang7757's Avatar
    If everything working , dont have to do anything give it little time see if anything acts up. I realized you started the other thread with LTE
    03-10-2020 11:43 AM
  18. Kawar's Avatar
    What do you mean?
    03-10-2020 01:21 PM
  19. Kawar's Avatar
    But ya I tried to get help for 2 things
    03-10-2020 01:21 PM
  20. mustang7757's Avatar
    03-10-2020 02:06 PM
  21. Kawar's Avatar
    O ya am working on 2 known issues for me is all
    03-10-2020 02:25 PM
  22. mustang7757's Avatar
    Ok
    03-10-2020 02:27 PM
  1. what is exndeded network mean on my s20 ultra 5g
    By Kawar in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 08-05-2020, 12:32 PM
  2. Call blocking not available on T-Mobile S20 Ultra
    By jarome in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-09-2020, 09:51 PM
  3. Will updating android 8 (oreo) to android 9 (pie) delete all apps and data?
    Last Post: 03-09-2020, 09:15 PM
  4. Samsung Tab 3 - Copying files to SD card
    By doubletop in forum General Help and How To
    Last Post: 03-09-2020, 05:16 PM
  5. Samsung Pay on S20 Series
    By jtcannonball in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-09-2020, 03:36 PM
