A
Android Central Question
Samsung Galaxy Note 8
I Forgot my "Volume Limiter Pin" I Set Up Very Long Time Ago... Please Help!
Welcome to AC!
Did you try reset settings?
Hi welcome to AC!I'm having the same problem. If I reset my settings, isn't that the same as a factory reset and I will loose valuable data?
Can't I just reset it? I don't ever remember setting up a PIN for this. Is there a default PIN that Samsung may have automatically set?
At this point, I would pay someone who can tell me about this volume limiter PIN.
