1. Note4me's Avatar
    I have a Samsung Note 4 (which I love). For two incoming calls lately, while the caller can hear me just fine, on my end the sound is badly garbled. If I switch to speaker, the garbling goes away. Is there a fix for this?
    I can't find the reply button? Found it.
    *Reply button missing again... Windows 10, ugh.
    Okay, the only thing I could think of that I did differently before the issues started was install Malwarebytes. So I googled it plus sound issues, and ta da! It *has* caused issues on computers at least. So I have uninstalled it, and will update if the issue is resolved. It would definitely explain why it is intermittent. It happened again today during a telemedicine appointment after not having an issue in days. ARGH. Hoping and praying this is the fix!
    03-25-2020 08:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do all calls over the main earpiece sound that way, or only certain calls? If it's all calls, then the earpiece speaker might be faulty.
    VidJunky likes this.
    03-25-2020 09:05 PM
  3. Note4me's Avatar
    Well, now the reply button shows up...
    I can't find the reply button? I'm winning today ... So far, it was only on the two calls, yesterday and today. The one yesterday was very bad, but it would clear up enough for a few seconds that we arranged to have them call me back the next day. The call today was fine. Today's other call cut out about 20 minutes into the call, same come and go garbling, and then I decided to try the speaker phone and that worked. Both calls were business calls (pharmacy and insurance). I haven't had an issue on any other calls.
    03-25-2020 09:22 PM
  4. Note4me's Avatar
    And thank you .
    03-25-2020 09:23 PM
  5. B. Diddy's Avatar
    Might be a little hard to troubleshoot, since it seems intermittent. If it becomes more frequent, see if it also happens in Safe Mode: https://www.t-mobile.com/support/dev...-galaxy-note-4
    VidJunky and Note4me like this.
    03-25-2020 11:00 PM
  6. VidJunky's Avatar
    While I agree that it would be very difficult to diagnose for two random calls your result raises questions.
    Has the phone been dropped, damaged or subjected to any physical stress that you're aware of? The Note 4 has a wired earpiece with a very small connector so it is less likely that a portion of the plug came out as its size kind of makes it an all or nothing connection. A simple test would be to play something on the device and then hold it in different positions to see if any position causes the speaker to stop working. The Note has a pretty high IP rating so I wouldn't think there would be anything touching the speaker but it could be possible that it is on its way out. It is 6 years old.
    If it turns out to be the speaker throw the device away and go get another. I kid but looking at this video the earpiece speaker is buried in the device and is ridiculously hard to get to. See marker 5:56...
    Barring physical issues with the speaker. Could there be something in the environment that could have caused this. These devices do everything they can to block out interference but they can't account for everything and actually FCC requires they must accept interference while not causing any. Sounds crazy but... Part 15 of the FCC rules, which governs unlicensed devices, incorporates a fundamental tenet of U.S. spectrum policy: an unlicensed device must accept interference from any source, and may not cause harmful interference to any licensed service. Anyway, were you in a particular area when these instances occurred? Was there a washer running, microwave, dishwasher, neighbor's shortwave radio? A time of day? Any correlation you can think of?
    B. Diddy and Note4me like this.
    03-26-2020 02:44 AM
  7. Note4me's Avatar
    Hmm. Yes, it fell about 3 feet onto a laminate floor, but that happened several days to a week before this issue, and it was dropped 3 feet previously (same spot- yay, cats) about a month ago and cracked the bottom left hand corner of the tempered glass cover, but not even badly enough that I felt the need to change it. I was at home when the speaker issue happened, and we are rural (farming community), so nothing new, except with the remote possibility of shortwave radio use or testing, considering the current corona virus panic. I will try it in safe mode and see if it will reproduce.
    I Just can't think of *anything* that has changed...
    Gosh, I don't think I want to take on disassembling this- I've taken a camera apart to clean a lens, and the dash of a minivan to replace a clock lightbulb (talk about poor design, lol) but yeesh. The sad part is, someone stole my phone about a year ago, and this IS my "new to me" phone. I haven't even finished finding and installing/changing all the tweaks I had done to my old phone... :/ Then again, if I run out of projects while we're "at home"... :P .
    Thank you so much! I will try to update and let you know if I find an issue, or if I need to replace the phone after all.
    03-26-2020 11:08 PM
  8. Note4me's Avatar
    Reply button is back, lol.
    04-02-2020 12:20 PM
  9. Note4me's Avatar
    04-02-2020 12:25 PM
  10. VidJunky's Avatar
    Thank you for keeping the thread updated. This may help the next person and it gives closure to your issue.
    04-03-2020 06:31 PM
  1. Has anyone got there $200 credit yet... from samsung.com preorder
    By Borgie in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-25-2020, 07:11 PM
  2. Managing Contact with Note 10+
    By hkula in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 03-25-2020, 06:18 PM
  3. What Android phones have; qualcomm x24 modem?
    By EndRacism in forum General Help and How To
    Last Post: 03-25-2020, 04:40 PM
  4. Largest keypad phone?
    By Paul_Iddon in forum General Help and How To
    Last Post: 03-25-2020, 01:14 PM
  5. Replies: 2
    Last Post: 03-25-2020, 12:39 PM
