    My phone keeps occasionally turning off. With a battey under 50 percent, sometimes when I try opening the camera app it turns off. In addition to that, with a battery under 20 percent, when I try turning on the data traffic, again it turns off.
    It gets more wierd when I try to charge it after getting turned off in the situations I described above. When I connect the phone to charger, it doesn't charge from 0%; It starts from something else like 10 or 50 percent.
    Why is it Iike this?
    I have an honor 8.
    Thenk you in advance.
    04-15-2020 01:42 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery might be failing. Does this happen in Safe Mode as well? https://www.getdroidtips.com/boot-hu...r-8-into-mode/
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    04-15-2020 01:44 PM
  1. Replies: 5
    Last Post: 04-16-2020, 05:41 PM
  2. What do this icons mean? (Phone in a circle icon) Please help
    Last Post: 04-16-2020, 05:08 AM
  3. How Annoying is the Waterfall Screen Palm Rejection on OP7P?
    By Mr MnmlEngr in forum OnePlus 7 & OnePlus 7 Pro
    Last Post: 04-15-2020, 02:47 PM
  4. My call list is upside down
    Last Post: 04-15-2020, 02:36 PM
  5. Why can't I open files without a specific app how
    Last Post: 04-15-2020, 09:32 AM
