1. pairadocs2000's Avatar
    my SD card shows up in the bottom corner near the clock, but whenever i click on it, it rarely shows the files that are on it. 1 out o 10 attepts will show the files (films). ther microSD card won't show up at all.
    SD card is sandisk ultra 16gb class 4
    oddly, there have been many times months ago that it worked fine
    also, the microSD card is inserted, but it does not show up at all
    any ideas what is wrong anyone?
    thank you
    02-11-2012 09:01 PM
  2. leeshor's Avatar
    I have an idea that your SD Card may be corrupted. Try re formatting it to NTFS in your PC.
    In the case where it isn't recognized, try restarting the TF with the card inserted but I think there is a file structure issue that the TF doesn't know how to handle.
    02-13-2012 03:49 PM
