1. freedda's Avatar
    The audio wizard app which came with my memo tablet--and which i need to make netflix audio come across as anything above a whisper--stops working, seemingly without reason. The only way I've found to get it going again is to shut off and then restart my tablet, which I seem to have to do once a day now.
    I've tried other ways to try to get it to work--disabling, then enabling audio wizard, force stopping it then starting again, clearing the cache--but nothing works except turning off the tablet and turning it back on again, which is a pain in the ****.
    I spoke with Asus a while ago. They did not acknowledge a problem with the app, and didn't offer a solution either, except to suggest that I try a volume boosting app from the play store (though they wouldn't make a recommendation of which one to get--which I thought was a pretty lame 'solution.')
    Does anyone hand a suggestion of what I should do?
    01-07-2015 02:57 AM
  2. B. Diddy's Avatar
    This would be a big hassle, but is worth trying if you have no alternatives: uninstall all of your apps besides Netflix (or do a factory reset and then only install Netflix), and see if the problem persists. If it goes away, then something else you installed may be causing it to become unstable.
    01-07-2015 11:40 AM
  1. Anyone know how to fix this alarm clock issue?
    By flamechica in forum Samsung Galaxy Note 4
    Last Post: 01-21-2016, 10:46 PM
  2. how I make name reader when someone calls me
    By Lasha Vachadze in forum Nokia XL
    Last Post: 01-12-2015, 07:37 AM
  3. Replies: 2
    Last Post: 01-10-2015, 10:40 PM
  4. Any way to change sort artist name like in iTunes?
    By rainingmuses in forum HTC One M8
    Last Post: 01-07-2015, 02:01 AM
  5. How do I know if my Nexux 5 has USB host support?
    By tomorrowisalongtime in forum Ask a Question
    Last Post: 01-06-2015, 10:25 PM
