1. MOHD SHAMRI's Avatar
    Asus Zenfone 2 Problem After Update System-11717001_986251494728939_1225291218_n.jpg
    Anybody can help..
    07-07-2015 02:31 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I assume it's stuck there? Is the circle still turning around? Was the update pushed over-the-air, or did you install it manually?
    07-07-2015 03:01 AM
  3. Albert Tan888's Avatar
    Wait for 2 to 3 mins on that screen, usually it takes longer than normal to boot every after update. Also whats ur internal flash memory, the bigger the longer. Another factor is apps installed other than the ones preloaded on your phone, the more apps the longer the boot process..
    Posted via the Android Central App - ASUS Zenfone 2 Z551ML
    07-09-2015 08:00 AM
  1. Replies: 1
    Last Post: 07-25-2015, 11:07 AM
  2. Replies: 6
    Last Post: 07-21-2015, 07:41 AM
  3. Okay to take 5.1.1 update (vzw) when unencrypted?
    By danielson2047 in forum Google Nexus 6
    Last Post: 07-07-2015, 11:30 AM
  4. Why my Phone App isn't installed after software upgrading?
    Last Post: 07-07-2015, 01:55 AM
  5. Data and Wifi conection problems on Straight talk Galaxy S4
    By Mr Bear1 in forum General Carrier Discussion
    Last Post: 07-07-2015, 01:52 AM
