1. gtt1's Avatar
    I keep having lock screen problems. I have set it so auto lock after 2 minutes and power press auto locks instantly. I use a pin so this always on defeats purpose
    Doesn't seem to work and I have to do a restart to get it on.
    Anyone else have this problem? Its a PITA as phone will switch on in pocket etc.
    Suggestions to fix?
    09-13-2016 10:11 AM
  2. B. Diddy's Avatar
    Sorry, can you clarify? Is the screen coming on by itself, unlocked? Or are you having problems getting the screen to turn on?
    09-13-2016 02:27 PM
  3. gtt1's Avatar
    Screen comes on from pocket etc. Setup to require a pin. See lock screen setup image.
    09-13-2016 02:58 PM
  4. B. Diddy's Avatar
    Do you have the double-tap to wake feature turned on? Maybe the phone is detecting inadvertent double-taps while in your pocket.
    09-13-2016 05:00 PM
  5. gtt1's Avatar
    Not sure where that is but if it needs a pin how would it turn it on?
    After restarting it currently is not occurring but that is the pattern, in a day or so it will begin again.
    My suspicion is some program overrides the setting somehow.
    09-13-2016 05:50 PM
  6. B. Diddy's Avatar
    Double-tap to wake is a ZenMotion. Go to Settings>ZenMotion>Touch Gesture. Under Suspend Mode, there's a switch for Screen On (Double tap to wakeup).
    If you have a PIN or pattern set up, and if the screen is locked, then double-tapping the screen will wake up the screen, but to the PIN or pattern entry lockscreen.
    09-13-2016 09:19 PM
  7. gtt1's Avatar
    I have not used the touch Gesture disabled that a long time ago due to problems with pocket presses.
    I have gone into auto-start manager and denied everything except calendar, yahoo mail and hangouts. I also noticed an old file from clean master was constantly starting even if I went in and manually stopped it.
    If I restart it works for a while but then goes back to staying on. Screen goes black but pressing the power button brings it back to an on status without having to enter my pin.
    If I did a full rest of the phone what occurs? I guess I then have to reload all the programs I want back. I think google will do this but it probably loads some programs I don't want back.
    09-16-2016 11:03 AM
  8. B. Diddy's Avatar
    Try a cache partition wipe, which won't erase any personal data: https://www.asus.com/zentalk/thread-9229-1-1.html
    09-16-2016 11:36 PM
  1. Best Tempered Glass Screen Protectors?
    By Dankees in forum LG Watch Urbane
    Last Post: 09-26-2016, 05:58 AM
  2. *HELP!* Locked out of phone after factory reset
    By Brandwin in forum Nexus 6P
    Last Post: 09-20-2016, 11:53 AM
  3. Samsung note 5 interested screen cracked
    Last Post: 09-13-2016, 12:03 PM
  4. Replies: 0
    Last Post: 09-13-2016, 10:10 AM
