1. asuszenfonedan's Avatar
    Hello, my Asus Zenfone 2 Laser with Android 6.0 that I recently got second hand has a problem that I can`t fix, the new battery I bought for it drains very fast, same with its old two batteries..So far I disabled all the apps I don`t need including google browser and all other google apps, updated all the apps that I use (no games or heavy load apps),disabled location and have 0 data usage in 2 weeks,dropped screen brightness to lowest, deleted the whole cache partition, factory reset the phone, but it still drains super fast, and yes,the new battery is good. Also,there are no apps that use alot of battery
    Is this a hardware problem? Should I dump this unit and buy a new one from the store?
    09-07-2017 09:23 AM
  2. belodion's Avatar
    Welcome.
    I suppose it could be a short circuit or something. Does it drain while the phone is powered off?
    09-07-2017 10:29 AM
  3. asuszenfonedan's Avatar
    I honestly did not try, but after digging through some papers from the old owner,I found that he replaced his charger before,and i`ve read somewhere else that (at least on Iphones) using a non-brand charge can make the phone malfunction, is that possible for this brand?
    09-07-2017 10:54 AM
  4. belodion's Avatar
    Let's ask the Zenfone 2 guys.... I'll move the thread.
    09-07-2017 11:15 AM
  5. asuszenfonedan's Avatar
    So I shut down the phone for a few hours and it dropped from 75% to 46%
    What should I do in this case? Drop this unit and buy a new phone?
    09-07-2017 01:45 PM
  6. asuszenfonedan's Avatar
    Well, I gave up on trying to fix this and I`m now waiting for my Xiaomi Redmi Note 4x to arrive, topic can be deleted
    09-15-2017 01:04 PM
  7. mek42's Avatar
    Sorry to wake an old thread but I have a peculiar case. I have been using Asus Zenfone 2 Laser for around two years now without any major issues. Suddenly a week ago the battery seemed to discharge in a very rapid phase, normally I can easily use it the whole day, now it was empty around lunch.
    I have another Laser 2 that is not used so I just swapped the batteries. Still battery dies at lunch time. So I go and do a factory reset to both phones, charge them to 100% and leave them at the table. In few hours the other is still over 90% and the second one is in 70%.
    Everything in the phones is identical; SIM card, firmware and software versions etc. Can there be a hardware problem, like a short circuit somewhere?
    05-13-2018 01:29 AM
  1. Verizon Galaxy S8 Facebook app draining battery at 0.01% when not even in use.
    By David_divaD in forum Samsung Galaxy S8 & S8+
    Last Post: 09-07-2017, 08:20 PM
  2. I want to ask about battery drainage of my s6 edge
    By Dr Asaad in forum Samsung Galaxy S6 edge
    Last Post: 09-07-2017, 03:03 PM
  3. I want to ask about battery drainage of my s6 edge
    By Dr Asaad in forum General Help and How To
    Last Post: 09-07-2017, 12:24 AM
  4. AT&T Galaxy S8 Notification Badge on Battery Setting?
    By pinkvikchick in forum Samsung Galaxy S8 & S8+
    Last Post: 09-06-2017, 06:27 PM
