1. SalvadorFreeman's Avatar
    Hello, I got this tablet (PO22 version) and the battery case. The trouble is, the tablet uses the internal battery in priority, drawing almost nothing from the accessory battery, until it gets down to almost zero and turns off, even though the accessory battery is well charged, as shown on the dual battery percentage.
    Is this a design fault, or am I missing something?
    At the moment, the accessory adds weight but no extra battery power.
    01-29-2017 11:30 AM
  2. Tim1954's Avatar
    Is there no button to push to activate the charger function? I have two battery cases and they both need to be manually started...
    01-30-2017 07:03 PM
  3. SalvadorFreeman's Avatar
    No button on my case.
    Where is your button?
    Also, the notification shows the level of charge both in the tablet and the battery.
    02-19-2017 04:28 PM
  4. Tim1954's Avatar
    Ah ok. The Samsung backpack had button on top left corner. The other one has a chrome button down low on the back...
    03-01-2017 06:32 AM
  1. Nougat battery life
    By lammy8 in forum Samsung Galaxy S7 edge
    Last Post: 03-17-2017, 12:09 AM
  2. samsung xcover3 randomly shuts down, battery seems OK.
    Last Post: 01-29-2017, 05:42 AM
  3. Nexus 10 battery drop 80% to zero
    Last Post: 01-28-2017, 03:15 PM
  4. Verizon Note 2 Battery Drain
    By decoyn in forum Ask a Question
    Last Post: 01-28-2017, 03:10 PM
  5. Bamboo Case
    By Bippoptl in forum OnePlus 3 & 3T
    Last Post: 01-28-2017, 02:39 PM
