11-19-2016 08:53 AM
64 123
tools
  1. keystone_56's Avatar
    Yes it takes a Nano in both slots.
    10-31-2016 12:14 AM
  2. jordans0nly's Avatar
    So when you say CDMA, you mean that only? No LTE?
    10-31-2016 12:24 AM
  3. keystone_56's Avatar
    Yes both slots take a Nano.
    10-31-2016 09:32 AM
  4. keystone_56's Avatar
    No, when I say CDMA Sim I mean Verizon or sprint. The second slot does not support CDMA carriers. The LTE works perfect for me. The only issue I am having is the APN settings are switching randomly. The default Apn settings great, but for some reason they randomly switch over to Trac Phone settings. When that does happen everything still works but text messaging. It's an easy fix, but is very annoying having to check those settings all the time. Hopefully someone can chime in with a fix.
    10-31-2016 03:25 PM
  5. jordans0nly's Avatar
    Man. You almost had me to pull the trigger, lol.
    10-31-2016 08:36 PM
  6. keystone_56's Avatar
    Yea problem just showed up. Seems to only happen when switching between WiFi and LTE. Still an awesome phone, I'll keep it regardless.
    10-31-2016 09:28 PM
  7. jordans0nly's Avatar
    So then you have to manually change the APN settings again after that happens?
    10-31-2016 09:48 PM
  8. keystone_56's Avatar
    Yes, I just go back to the APN settings and select restore to default.
    10-31-2016 09:53 PM
  9. keystone_56's Avatar
    After the update today it has not happened again. I'm hoping that solved the problem.
    jordans0nly likes this.
    10-31-2016 09:55 PM
  10. maclancer's Avatar
    I am looking forward to the axon 7 mini... I am going to upgrade from a Moto G4.
    10-31-2016 09:58 PM
  11. HeffaZord's Avatar
    For anyone interested I am running both Verizon and AT&T simultaneously on this phone. I have had it a couple of days now. Verizon works only in Sim 1. I tried it alone this morning and without wireless downloaded a scanned 40 page pdf in seconds. WhatsApp appears to work as well on both lines. I am also using the Xiaomi Mi5 for the same thing. The Axon 7 is superfast and strong compared to the Xiaomi but the Xiaomi seems to use the two cards a little easier. It may just be my imagination, but the bottom line is that both phones seem to work fine with one sim card from each carrier. I took my sim card from a Nexus 5x and the AT&T card from a Windows Lumia 950, popped them both in and there you go - two networks on one phone.
    Are you able to switch to using only your AT&T data (4G/LTE) when you are running on both AT&T and Verizon?
    11-18-2016 03:48 PM
  12. Rumblee1's Avatar
    I've got the mini. Had it for a week now. Its an awesome phone. Certainly not as fast as my S7 edge or pixel, but holds its own. I bought it purposely for the Dolby atmos and hifi dac amps to listen to my media. Nothing else comes even close.
    maclancer likes this.
    11-18-2016 07:36 PM
  13. maclancer's Avatar
    That's why I want to get one... not because is a flagship phone but because the powerful audio that it has.
    11-19-2016 05:45 AM
  14. Rumblee1's Avatar
    Im using a project fi sim card in it, so I get all that comes over data and WiFi. Also downloaded hangouts Dialer. You can make calls with it using data from your fi account.
    11-19-2016 08:53 AM
64 123
  1. the screen of my cellphone is blank
    Last Post: 07-25-2016, 05:30 AM
  2. Replies: 1
    Last Post: 07-25-2016, 05:28 AM
  3. Replies: 1
    Last Post: 07-25-2016, 05:27 AM
  4. NO contacts on gmail after sync and reset
    Last Post: 07-25-2016, 05:25 AM
  5. Smart Lock Not Working
    By Brew Swayne in forum Samsung Galaxy Note 4
    Last Post: 07-23-2016, 08:20 AM
